Disc brake brackets for Ford 9" - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 05:19 PM
fearsomefairmont's Avatar
Hi guys,
I am thinking of putting a 9" I have lying around in my '72 Cutlass instead of upgrading the 10-bolt currently in it, which has terrible gears (2.73?) and an open diff.
I am upgrading the drum front brakes to 12" rotors and correspondingly I would like to put discs on the rear as well. Currie will be the source for the suspension brackets, and I have 31-spline trac-loc chunk with 3.50 gears.
But, I really need caliper brackets. I have found apparently a bazillion disc brake kits, but I don't see the need to buy a several hundred dollar kit for cheap, junkyard parts. I guess I could fab the brackets myself, but I would rather save some time. I also don't mind welding on new housing ends, if you have a recommendation that would make the disc retrofit easier.
Give me some direction!!!
Cheers,
Andy
Old 05-10-2006, 06:09 PM
poncho62's Avatar
Wiki Edits: 5
Give Scarebird a try....They may have something to help you out.
Old 05-11-2006, 06:11 PM
S10xGN's Avatar
Gotta love a turbo!
I got these brackets water-jet cut for $40.00 (2 pair). They put a C4 'Vette front rotor on a Ford 9" with small bearing ends. As you can see, there is minimal spacing misalignment that was taken care of with some 0.070" spacers.
I'd do it again, but using the correct rotors & calipers - I'm having to run a dual M/C setup with balance bar to get the brakes proportioned correctly. Total for the rear axle: less than $200.00 including new rotors and rebuilt calipers.
Russ
ID:	12122   Click image for larger version
ID:	12123   Click image for larger version
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
