Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brake caliper dragging
Old 01-09-2010, 12:58 PM
Rickracer's Avatar
Rickracer Rickracer is offline
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
You need to determine if it's the caliper hanging up or possibly a bad hose. Jack that wheel up, pump the pedal up hard, make sure that wheel is still grabbing, then crack the bleeder screw. If it still has pressure in it, and the wheel releases, you've probably got a hose going bad internally.
