disc brake caliper dragging
installed new callipers all the way around, but the Left rear is dragging/sticking. I know for one i can hear it .two A LOT of brake dust on the wheel. how can this be fix?
You need to determine if it's the caliper hanging up or possibly a bad hose. Jack that wheel up, pump the pedal up hard, make sure that wheel is still grabbing, then crack the bleeder screw. If it still has pressure in it, and the wheel releases, you've probably got a hose going bad internally.
same thing on my 81 c10 it was a bad hose do like Rick said jack it up pump it up and then crack the bleeder if it lets go it is a hose if it dont it is the caliper
| Ford Galaxie Disc Brake Conversion | CrashFarmer2 | Suspension - Brakes - Steering | 5 | 04-10-2010 04:52 PM |
| My 9inch rear end disc brake setup. | 1937FordCoupe | Suspension - Brakes - Steering | 0 | 01-15-2007 06:01 PM |
| Taurus Brake Caliper...Slow Release. | awbazar | Suspension - Brakes - Steering | 5 | 02-22-2006 04:33 PM |
| Disk brake caliper & steering arm hitting | gator412 | Suspension - Brakes - Steering | 3 | 05-28-2005 10:31 PM |
| disc brake rotors | bondsman | Suspension - Brakes - Steering | 6 | 11-30-2003 06:20 PM |
