Does the truck stop in a straight line? Does it stop as it should as far as distance? If yes to both, probably OK - but ...... those calipers may not be matched as far as fluid capacity with the fronts (whatever they are). If you have a 1" piston in the fronts, it will take less fluid to move a distance then say a 2" or multiple pistons on the rears. A proportioning valve will only modify the pressure about 55-60% so wide open - no change. As far as percentage of braking - a pickup may be as bad as 70/30 though 55/45 or 60/40 would be normal. Using wear as your indicator - the backs on my '31 with identical Wilwood calipers on all four corners show no wear with just a minimum of markings on the rotors
The truck stops nicely and in a straight line. The front calibers are GM stock calibers (not sure the year?) that came with the front conversion kit from Classic Performance Parts. I'm assuming that the rears should at least show some wear on the rotors if the pads are working. I understand the front has more stopping power which is evident in my case. I guess my question is how do I get the rear calipers to apply more stopping that what they actually do now. I'm assuming that the Proportion valve being wide open would allow the most pressure of brake fluid to the calipers? I appreciate the info, it's good info...
According to the Rock Auto Parts catalog, the Seville normally has 2-15/16" pistons for the fronts while the tried and true '80s GM Monte Carlo size car has a 2-1/2" piston. The Sevilles's are then 7/16" larger in diameter. I know you said that you have the e-brake calipers, which are supposed to be 2-1/2 - maybe - as it does look like there are some with the 2-15/16 rears just to confuse the issue
If you have the 2-15/15 version, this calculates as each front piston having 4.9 sq in of surface area with the rears at 6.77 or about 25% (round numbers) more surface area. A physics law(Boyle's) - "Pressure and Volume are indirectly propotional to each others. if you increase the Area the pressure will be decresed, and if you decrease the area of the applied pressure, the pressure will be automatically increased. Hence, pressure is indirectly propotional to area." This tells me you might have a problem in that the rear caliper pistons may be too large and not giving you enough brake power. In actuality, those calipers should probably be in the 2 to 2-1/4 diameter range Can you tell - I'm being cautious. Too dam' many variables when you deal with OEM 'stuff' adapted to our hobby cars (I really like my aftermarket Wilwoods )Dave W |
I read some where
that rear disk brakes only add 22% to the total braking with a front engine vehichle. If thats the case I dont see where it is an advantage over brake shoes that don't drag all the time thus giving better gas mileage!! maybe in all out racing rear disks would be an advantage. There is a cost savings here also... If all the above is correct
The reason I'm going with the Cadillac calibers is the ebrake system which is easy to use and adapt to my stock truck ebrake system. I was thinking about going with the stock calibers like the front and be done with it and not utilize an ebrake at all. I'm sure that would fix my issue. The other option is going with wilwood or aftermarket caliber which are expensive but work nicely. I may also check into a line lock type system that locks the rear brakes when applied which I could use as a ebrake and would allow me to use standard front calipers. The Cadillac calibers weren't cheap either and it would be nice to have them working properly. What's the purpose of having 4 wheel disc if they don't work... Thanks for your help and advise!
If you do go with smaller calipers, the option is to use a pinion mounted parking brake. While they really aren't very good, they at least satisfy the letter of the law and will at least hold somewhat. I've had this one on 2 cars, but I see they have a better one now:
http://www.tsmmfg.com/pinionmountedpb.html Now - the BS of 22% - sorry, but there are better reasons to switch to discs. They seldom if ever will fade to uselessness, they will work just as well when wet, wear at a much slower rate, help fuel mileage by not contacting the rotor when not applied plus weigh significantly less, are easier to service, and additionally, shorten stopping distance by a LOT |
just as a test-try putting the prop valve in the front half of the system
Well in my life
i have changed as many rotors, pads, and callipers as I have brake shoes. So to me having them in the rear is only a 22% high for my car.. And another added costs versus a set of cheapo brake shoes and I still get 22% how can you lose???
| Ford 9" disc brake upgrade question | bebopwally | Suspension - Brakes - Steering | 3 | 07-04-2010 03:49 AM |
| Ford 9" Disc Brake Conversion | fredbaker | Suspension - Brakes - Steering | 18 | 09-23-2009 03:30 PM |
| Disc brake brackets for Ford 9" | fearsomefairmont | Suspension - Brakes - Steering | 2 | 05-11-2006 06:11 PM |
| Disc brake conversion ford 9" | magnum2u | Suspension - Brakes - Steering | 6 | 08-30-2004 09:33 PM |
| Disc brake conversion on Ford 9" | shockers69 | Suspension - Brakes - Steering | 1 | 07-01-2004 10:26 PM |
