disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2007, 07:02 PM
my first post is : what type, make or model vehicle would be a good source to swap steering and disc brake from that will fit on to my 67 chevy pick up? street strip build on this truck(383 th350 3.73 rears). i have searched through the sterring, brake and suspension section and found nothing that pertains to my 67 swap. any ideas??
thanks in advance!
Old 06-06-2007, 07:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks in advance!
why would you post this in the section for web site suggestions and board help?
I would post the question in the brake forum-section
Old 06-06-2007, 07:56 PM
gotcha' i'l get it right soon
Old 06-06-2007, 08:09 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I'll reply here, as I'm sure the mods will move it to the appropriate forum.
The quick answer is: see my journal.
73-87 C10 (73-79 preferred) front suspension clip will likely be a virtual "bolt-on" for your '67 as well.
Early Classic Enterprises (and many others) offers a 6-bolt rotor to replace the 5-bolt one as well (if you want to keep a 6-bolt pattern).
Reply here with any other questions.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Disc Brake Conversion On 1937 Plymouth jjp Suspension - Brakes - Steering 1 01-30-2007 01:17 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
