disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 02:22 PM
peppers's Avatar
do you guys use locktite on your caliper and backing plate bolts? do the following torque spec's sound right: 80ft-lbs lower ball joint, 50 upper ball joint, 35 tie-rod ends castle nuts, 30 caliper bolts. these are specs. I used from the installation manual. I have a local shop telling me they use loctite and 300ft lbs. from a air gun on all these bolts! which is correct?
Old 03-08-2010, 03:42 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
The Loctite is a good idea, but if the shop that told you to use 300lbs on an air gun really does this, they are lucky they haven't killed anybody yet.
Old 03-08-2010, 05:17 PM
Turdpolisher's Avatar
That's insane!!
300 ft/lbs of torque is insane. It would take a 4 foot cheater bar to create that much.
Old 03-16-2010, 12:43 AM
you guys havent worked at a dealer huh? yould be amazed what gets torqued with the air gun. basicaly everything past the head bolts. does require some touch though lol.
Old 03-16-2010, 06:06 AM
Rickracer's Avatar
I've been wrenching professionally for almost 35 years, several at a Chevy dealer. Do I use a torque wrench on ball joints? NO, but I don't use an air gun on them either,
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 02:12 PM
disc brake conversion kaptmikey Suspension - Brakes - Steering 5 05-30-2007 11:53 AM
Disc brake conversion for a 67' mustang Pencilneck314 Suspension - Brakes - Steering 6 12-07-2003 03:24 PM
Disc Brake Conversion 57tommy Suspension - Brakes - Steering 9 08-19-2003 04:40 PM
