-   -   disc brake conversion (http://www.hotrodders.com/forum/disc-brake-conversion-174525.html)
peppers 03-14-2010 08:54 PM
I just finish a front disc brake conversion. I am bleeding the wheels and all four wheels are now locked up?? Is this normal and what should I do now?? : :confused:
JEREMY067390 03-15-2010 09:05 PM
deffinitly not normal. did you change the proportioning valve? drum prop valves have residual pressure valves built into them. still doesnt explain the rear though. did you do anything to the rear? shoes ect? those have an adjustment, should drag an *** hair thats all.
cobalt327 03-15-2010 11:04 PM
For starters, be sure the MC push rod is adjusted correctly, and that the pedal is FULLY returning all the way out when at rest.
