disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2010, 08:54 PM
peppers's Avatar
I just finish a front disc brake conversion. I am bleeding the wheels and all four wheels are now locked up?? Is this normal and what should I do now?? :
Old 03-15-2010, 09:05 PM
deffinitly not normal. did you change the proportioning valve? drum prop valves have residual pressure valves built into them. still doesnt explain the rear though. did you do anything to the rear? shoes ect? those have an adjustment, should drag an *** hair thats all.
Old 03-15-2010, 11:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For starters, be sure the MC push rod is adjusted correctly, and that the pedal is FULLY returning all the way out when at rest.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 01:12 PM
disc brake conversion kaptmikey Suspension - Brakes - Steering 5 05-30-2007 10:53 AM
Disc brake conversion for a 67' mustang Pencilneck314 Suspension - Brakes - Steering 6 12-07-2003 02:24 PM
Disc Brake Conversion 57tommy Suspension - Brakes - Steering 9 08-19-2003 03:40 PM
