disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 04:53 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
two question. first, will 1979 nova disc brakes fit a 71 nova , second the disc brakes were off a car with power brakes will this setup still work if i just leave the booster off? and can i used my existing master?
Old 03-02-2011, 04:56 PM
oh yeah i will have to swtich proportioning valves correct?
thanks in advance
Old 03-02-2011, 04:59 PM
poncho62's Avatar
Wiki Edits: 5
Pretty sure not....71 was a rear steer (up until 74, I think)...79 is front steer....so the spindles wont fit
Old 03-02-2011, 05:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You will need the correct M/C without the booster you will need a manual brake M/C And the rod IIRC it will be different also form the power to the manual brake system. JMO
Cole
Old 03-02-2011, 05:29 PM
ericnova72's Avatar
More for Less Racer
Rotor and caliper will interchange, but the spindle will not.
'68-74 Nova is rear facing steering arm, and the arm is removable(bolted to the spindle). '75-79 Nova is front facing steering arm, and arm is cast into the spindle and not removable.
Old 03-02-2011, 06:20 PM
not sure if this is a stupid question or not but can the spindles be swapped from side to side in order to make it fit the rear steering
Old 03-02-2011, 06:45 PM
whats the difference from the drum brake spindles and the disc brake spindles ... does the drum brake spindles have holes to accommodate the caliper bracket? in other word whats stopping me from useing the disc brakes on my existing drum brake spindles?
Old 03-02-2011, 07:18 PM
Nope.
Will 75 nova spindle work on a 71
disc brakes nova
Here's how to machine drum spindles to become disk spindles. First gen Camaro (as discussed in the link I posted) uses the same spindles as the 68-74 Nova. The caliper brackets are available repro.
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
Old 03-02-2011, 08:19 PM
Wiki Edits: 27
switching spindles
when you switch from rear to front steer, not getting the correct spindles , the ackerman angles will be reversed, the wheels will toe out on turns , squeel and wear the tires. A lot of rat rods put the tie rod in front of the axle . one of the reasons they are not safe.
Old 03-02-2011, 09:10 PM
thanks guys i will keep my eye out for another kit that would fit
Old 03-03-2011, 07:01 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
69-72 GM A-body -- Chevelle, Skylark, Lemans, Cutlass
If just looking for spindels----67-72 (calipers were different on the 67/8 cars)
69 Camaro------again---spindles will work from 67-69
Disc brake conversion Jethrotrc Suspension - Brakes - Steering 1 12-22-2009 10:40 AM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 09:20 PM
disc brake conversion TIMDOGG Suspension - Brakes - Steering 3 06-06-2007 09:09 PM
Disc brake conversion Chorny Suspension - Brakes - Steering 2 07-29-2004 01:49 PM
'57 bel air disc brake conversion mitmaks Suspension - Brakes - Steering 1 12-20-2002 08:22 PM
