Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Disc Brake Conversion? 1962 Ford Falcon Futura?
Old 01-23-2012, 01:52 PM
Jeff Van Stemp Jeff Van Stemp is offline
One more thing
I am changing my '62 Falcon to disc - you will probably need to also change your upper control arms and ball-joints because the stock '62 has a smaller diameter ball joint shaft. I ordered the upper control arms and ball-joints as a kit from CJ Pony - they aren't too bad - around $72 each side. (They are actually for 65-66 Mustang) I am also going to order the center-link tie-rod end kit from CSRP for about $375.
