-   -   Disc Brake Conversion? 1962 Ford Falcon Futura? (http://www.hotrodders.com/forum/disc-brake-conversion-1962-ford-falcon-futura-194292.html)
chadc 03-11-2011 05:07 PM
Hi, is it possible to "easily" convert a 1962 Ford Falcon Futura's front drum brakes into disc brakes? Are there any conversion kits out there to do so? i haven't found anything. Thanks!
poncho62 03-11-2011 05:15 PM
http://www.scarebird.com/index.php?id=1
eloc431962 03-11-2011 05:22 PM
Yes there out there depending how much you want to spend. http://www.google.com/#q=1962+falcon...c4d96e154bbdb2 .
Granada brakes will also work.
Cole
matt167 03-11-2011 06:00 PM
just keep in mind. the granada swap will require the use of tie rod adapters from www.discbrakeswap.com as they changed in 1964
eloc431962 03-11-2011 06:13 PM
Yep i forgot about that good save Matt. :thumbup:
Cole
robertfchevelle 03-11-2011 09:49 PM
robertfchevelle
I have just converted the front brakes on my 38 chevy hot rod (comaro front end) to disc brakes and moved the master cylinder underneath the floor. I have two problems. 1) the brake pedal will not come all the way up after applying the brake. 2) the front brakes are dragging (even when I pull the brake pedal all theway up). Any help would be appreciated.
Thanks.
JeffB 03-12-2011 12:47 PM
Refer to this link: www.fordfalcon2000.com/restoration a list will pop up for you to click on.
Bonneville462 03-13-2011 07:49 AM
I used the Scarebird brackets with good results.. He provides excellent tech help..
Jeff Van Stemp 01-23-2012 12:52 PM
One more thing
I am changing my '62 Falcon to disc - you will probably need to also change your upper control arms and ball-joints because the stock '62 has a smaller diameter ball joint shaft. I ordered the upper control arms and ball-joints as a kit from CJ Pony - they aren't too bad - around $72 each side. (They are actually for 65-66 Mustang) I am also going to order the center-link tie-rod end kit from CSRP for about $375.
