Disc Brake Conversion? 1962 Ford Falcon Futura? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2011, 05:07 PM
Hi, is it possible to "easily" convert a 1962 Ford Falcon Futura's front drum brakes into disc brakes? Are there any conversion kits out there to do so? i haven't found anything. Thanks!
Old 03-11-2011, 05:15 PM
poncho62's Avatar
Wiki Edits: 5
http://www.scarebird.com/index.php?id=1
Old 03-11-2011, 05:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes there out there depending how much you want to spend. http://www.google.com/#q=1962+falcon...c4d96e154bbdb2 .
Granada brakes will also work.
Cole
Old 03-11-2011, 06:00 PM
Wiki Edits: 31
just keep in mind. the granada swap will require the use of tie rod adapters from www.discbrakeswap.com as they changed in 1964
Old 03-11-2011, 06:13 PM
eloc431962's Avatar
Wiki Edits: 37
Yep i forgot about that good save Matt.
Cole
Old 03-11-2011, 09:49 PM
robertfchevelle
I have just converted the front brakes on my 38 chevy hot rod (comaro front end) to disc brakes and moved the master cylinder underneath the floor. I have two problems. 1) the brake pedal will not come all the way up after applying the brake. 2) the front brakes are dragging (even when I pull the brake pedal all theway up). Any help would be appreciated.
Thanks.
Old 03-12-2011, 12:47 PM
JeffB's Avatar
Refer to this link: www.fordfalcon2000.com/restoration a list will pop up for you to click on.
Old 03-13-2011, 07:49 AM
Bonneville462's Avatar
I used the Scarebird brackets with good results.. He provides excellent tech help..
Old 01-23-2012, 12:52 PM
One more thing
I am changing my '62 Falcon to disc - you will probably need to also change your upper control arms and ball-joints because the stock '62 has a smaller diameter ball joint shaft. I ordered the upper control arms and ball-joints as a kit from CJ Pony - they aren't too bad - around $72 each side. (They are actually for 65-66 Mustang) I am also going to order the center-link tie-rod end kit from CSRP for about $375.
1962 Impala disc brake conversion 62impala Suspension - Brakes - Steering 9 01-03-2014 07:57 PM
1962 Falcon disc Brake conversion???? RUDY Suspension - Brakes - Steering 3 01-23-2012 07:33 AM
Putting a 302 in a 1962 ford falcon futura...Motor Mounts?? futuraresto Engine 3 01-26-2011 09:08 AM
need picture of 63 convertable ford falcon futura Dave M,King Introduce Yourself 2 06-10-2004 11:59 AM
`33 Ford disc brake conversion Mike Humphrey Suspension - Brakes - Steering 0 02-17-2002 02:49 PM
