Disc Brake Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2003, 08:51 AM
New Member
DISC BRAKE SWAP YES OR NO...HELP
I NEED ADVICE ON FRONT DISC BRAKE CONVERSION. I HAVE A 57 CHEVY & WANT TO KNOW IF CHANGING TO DISC REALLY HELPS THE OR IS THE IMPROVEMENT NOT WORTH THE CHANGE. PLEASE LET ME HEAR YOUR OPINION GOOD OR BAD.
THANKS FOR ALL YOUR HELP.
Old 08-18-2003, 11:27 AM
EBlack36's Avatar
Rebuilt Excitment
First Thing 57, please do not type your entire message in upper case, it looks as if you are mad or something. Now as far as the disck brake conversion, I did it on the 57 210 wagon that the wife and I own, you ask if it was worth it, heck yes it makes the car a safer car. these cars originally came with a single master cylinder and small drum brakes, when changing to disk you are going to convert to a dual master cylinder which will then separate your front and back brakes.
Old 08-18-2003, 01:43 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
We just put a set of discs in the front of a 69 C10 and even without power assist, it made the biggest difference and was worth every drop of sweat and penny!
PS, it does look like you're screaming at us...
Old 08-18-2003, 02:08 PM
New Member
Sorry about the caps guys I can be small too...lol. I just wasn't sure if the disc brakes made that big of a difference. did you use a adjustable proportioning valve or a set one?
Old 08-18-2003, 02:54 PM
EBlack36's Avatar
Rebuilt Excitment
I used a set one, My entire booster/master cylinder came off of 86 s-10 blazer because I wanted it to set flat against the firewall, but if I was going to start over I would buy a complete conversion from someone like Master Power Brake or Stainless Steel Brakes.
Old 08-18-2003, 03:01 PM
New Member
Thanks, I have a power brake booster from Mcgaughy's so this is the next step in getting the car back on the road. I had talked to 2 people with 55 chevys & they told me it didn't make that big of a improvement.
Old 08-18-2003, 03:16 PM
Wow, that's surprising. I can't see how, but the C10 we did had horrible brakes to begin with. We also had a set prop valve.
Old 08-18-2003, 05:17 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
This week end I went to Branson Mo. for there yearly cruise, there was 2000 cars on the strip. several places was keep wet down for burn outs. I was driveing my 66 Elcamino, there was 80,000 spectaters yelling and cheering, guess what this old man did. The devil got me. I set up for a good burn out on my brand new B F Gs, Just as I let off to let the smoke clear The front wheel cylinders blew out. I did get the emergency brake set just as I ran up on a 50 studebaker with a blown 502 engine. If I had a dual master cylinder I could have finished the cruise. I`m putting one on today with 4 wheel disc. HTH
Troy,
Old 08-19-2003, 03:30 PM
302 Z28's Avatar
Disc brakes did mot make that much of an improvement? All I can say is they didn't do it right if that is the case. Drum brakes on the tri 5's are the pits. When I converted my 56 a long time ago to disk brakes I was amazed at the difference.
Vince
Old 08-19-2003, 03:40 PM
New Member
Thanks for everybodys input.. i have mcgaughys power booster and will get the rest of his brake setup.....thanks again for everybodys help
