disc brake conversion 29 pontiac
Does anyone know if the spindles on a 29 pontiac straight axle are the same as a 28-29 chevrolet? I am trying to do a disc brake conversion and no one lists this car...imagine that.
Thanks |
Have you tried Fatman?
I'm trying to keep the straight axle under it. I didn't think they did anything but mII conversions. I'll chck tomorrow
Try Master Power Brakes in N. Carolina. They might be able to help. The catalog that I have says they will make a custom conversion kit for almost any classic car. It is an older catalog so you might need to call to see if they still do that. check their website for the phone #.
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Pontiac disc brakes
Through some thorough investigation I discovered that the only difference between a 29 Pontiac and a 32 Chevrolet was the backing plate bolts are .120" further apart. A ECI conversion kit worked wonderfully with a little milling on the front bolt holes. They are great to work with and helped me after going back and forth with specs. I would highly recommend them to anyone converting to disc brakes.
| Ford Galaxie Disc Brake Conversion | CrashFarmer2 | Suspension - Brakes - Steering | 5 | 04-10-2010 04:52 PM |
| drum to disc conversion kits | dmented | Suspension - Brakes - Steering | 4 | 06-06-2007 09:06 PM |
| 1956 Pontiac Starchief disc brake conversion | lsb | Suspension - Brakes - Steering | 11 | 02-28-2006 08:32 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
