I would see wwwspeedwaymotors.com, they seem to have a lot of different disc brake set ups. If they don't have it the may be able to direct you to someone that does. You also may be SOL on a bolt on type "kit" so an axel change or machining may be in order. Personally I would change out the entire front end for a new dropped axel/spring/shock unit. That big mopar is a heavy weight and might cause some problems with the 80 yr. old parts.
