Disc Brake conversion on a '31 Chevy axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2011, 11:12 AM
31chevymike's Avatar
NOSTALGIA HOT RODS WILL RULE!
Last journal entry: Second Resto finished and looking cool!
I am dropping the mighty 392 Chrysler Hemi within the original rails of my '31 Chevy coupe. I recently aquired an original '31 Chevy dual leaf spring front axle and need to purchase a disc brake conversion kit if available... Can anyone advise as to make this happen? I appreciate any info greatly and regard this site as a valuable service! Mike
Old 08-07-2011, 02:01 PM
327NUT's Avatar
I would see wwwspeedwaymotors.com, they seem to have a lot of different disc brake set ups. If they don't have it the may be able to direct you to someone that does. You also may be SOL on a bolt on type "kit" so an axel change or machining may be in order. Personally I would change out the entire front end for a new dropped axel/spring/shock unit. That big mopar is a heavy weight and might cause some problems with the 80 yr. old parts.
Old 08-07-2011, 02:31 PM
Irelands child's Avatar
I tend to agree that the original axle would probably be best changed to something newer. Too many rears of bad roads have probably taken their toll. Here's an interesting site that might help find something else plus some good info in the link's Tech Articles. But if you do choose to add disc's to your existing axle, you will probably be on your own.
Dave W
Irelands child
Old 08-07-2011, 08:52 PM
Thanks for your replies... Note that I purchased brand new leaf springs from Eaton Detroit Springs and even added two more leafs (from 6 or 7 originally) on each side for the extra weight of this hemi... I'm not going for the "street rod" style as you can clearly see from my avatar photo or if you checked out my albums. My goal is to re-build my coupe as an early sixties show car as close as possible. I'm even looking into purchasing the So-Cal Buick drum brake look to cover the rotors... Mike
Disc Brake Conversion for 14 bolt semi floating axle Torque454 Suspension - Brakes - Steering 0 06-25-2010 09:56 PM
63 chevy impala disc brake conversion 63impalass Suspension - Brakes - Steering 9 12-12-2007 09:38 PM
1961 Chevy Disc Brake Conversion Kit rock falls Suspension - Brakes - Steering 1 08-22-2007 02:06 PM
56 Chevy Bel-air 150 Disc Brake Conversion/Swap heavy2dachevy Suspension - Brakes - Steering 1 07-03-2006 01:40 PM
66' chevy disc brake conversion Hades212 Suspension - Brakes - Steering 2 11-26-2004 11:50 AM
