Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brake conversion/distribution block/Proportioning valve -- help
Old 05-05-2011, 08:51 PM
poy41 poy41 is offline
Originally Posted by joe_padavano
the drum brake cars used a distribution block only. This is simply a tee fitting with a differential pressure switch that illuminates the BRAKE light on the dash if you lose pressure in one half of the system.
thats what i have now
so something like this should work, only have to hook up one of the wires tho.
