Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brake conversion/distribution block/Proportioning valve -- help
Old 04-22-2012, 02:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
After looking at this a second time, are you sure there will be adequate flow/volume from a single port of the combo valve to feed both ports out of the distribution block to the front calipers? I believe your better off plumbing it correctly, not "easily".
