Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brake conversion/distribution block/Proportioning valve -- help
Old 01-07-2013, 09:50 AM
joe_padavano joe_padavano is offline
Originally Posted by Rosylab View Post
Thanks for the info Cobalt327. I think I'll replace the dist block with a T-fitting to service the front brakes and run a new line to the rear. Right after I install the new Edelbrock intake manifold and carb.
Why? The aftermarket combo valve already has separate outlet ports for the two front wheels. Just plumb from these outlet ports to each front wheel and from the rear outlet port to the rear wheel junction block on the rear axle. Discard the original distribution block. Problem solved.
