Disc brake (Fat Man) Must ll, lfs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 12:29 PM
All welded in, installing my calipers and pads, my que, which way does the pad w/riveted spring tab go?Also they sent 2spring connectors(to hold pads together) I am assuming does anyone have a pic w/caliper loaded w/ pads etc? Thanks Dana
Old 01-04-2012, 09:49 AM
454 Rattler's Avatar
NEVER SATISFIED !!
You could always contact Fat Man. It's not a dumb question. They've probably heard it a hundred times.
454 RATTLER
Old 01-04-2012, 04:08 PM
The 2springs r 4 ea pad to hold together, and riveted spring is 4when pads wear down it will start to screetch. OF COURSE, oh well now I know, thanks 454,
Old 01-08-2012, 12:12 PM
allthumbs's Avatar
rear suspension
I also have a 39 Chevy, this one a 2 door master deluxe. The suspension in the rear has new leafsprings and air shocks with a 2 inch block spacer mounted above the leaf springs to bring the rear end down 2 inches. The front has a 2 inch drop axle c/o Fatman.
the ride in the baxck is lousy. The axle bottoms out frequently with 2 people in the back seat and the rear of the car is still hiked up too much.
Any ideas on simply bringing the height down while having enough suspension travel to take up bumps with 2 passengers and supporting the load? air suspension? Any less expensive remedies? notching the frame to create more room for the axle to travel/ that sounds a little radical.
Allthumbs in Despair
Old 01-08-2012, 07:17 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
well, if you look under the rear of the car at the axle
take note of how much room is between the top of the axle and the frame
you will need at least 3"-4" suspension travel for any kind of ride comfort
add to that, your wishes of lowering the rear 2" more
do you see 6"+ because thats what you will need, to have both lower and nice ride
if not, c-notching the frame is about the easiest fix
Old 01-22-2012, 11:33 AM
allthumbs's Avatar
lowering 39 chevy rear end
Thanks, Matt. I was afraid that was all that was left to do.
Allthumbs with less despair
Help with 68 camaro emergency brake install disc brake jdp2603 Suspension - Brakes - Steering 4 02-13-2010 07:56 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 08:20 PM
Mecanical disc brake caliper for parking brake? bigun Suspension - Brakes - Steering 4 12-15-2005 08:43 PM
23T Hub and Disc Brake dee004 Suspension - Brakes - Steering 3 11-25-2005 02:10 PM
