disc brake interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2008, 10:48 PM
I am wnting to know if the disc brakes on a 1974 Cutlass will interchange with a 1980's Montecarlo. I need the pads and hoses because I put 1980 Monte spindles on my 1970 Buick Skylark and now I have complete 1974 Cutlass and I want to finish off the conversion .The Monte stuff bolted right on real easy so far.
thanks, Clint
Old 12-10-2008, 08:57 AM
thanks, Clint
The 80 G-body spindles may bolt to a 70 A-body, but the taper on the ball joint studs is different. THIS IS NOT SAFE! Get the correct spindles or adapt the later ball joints with the correct taper.
Old 12-10-2008, 09:41 PM
interchange
I put the same ball joints as the spindles . I don,t want to create problems I am just wondering if the calipers are interchangeable from the 1974 Cutlass to the 1980's Monte. I will find out soon enough when I am hanging on to them and physically compare. Thanks Clint
Old 12-11-2008, 07:50 AM
Smart move. Most people don't realize this is necessary. I believe the G-body cars use the metric calipers, the 73-77 cars use the larger calipers.
63 impala front disc brake conversion derwood3 Suspension - Brakes - Steering 6 12-27-2012 05:04 PM
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 01:12 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
79 LTD disc Brake rearend Mike Pomerantz Suspension - Brakes - Steering 2 09-11-2003 11:19 AM
