Disc brake pad compounds - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 04:43 PM
I have two rides that have GM front disc brakes using semi-metallic pads and both seem to fade a little under sustained heavy braking. Would some of the new compounds like Ceramic or Ferro-Carbon pads help?
Old 07-09-2012, 05:00 PM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
When I put ceramic pads on my 2003 durango, they squeeled from day one and warped my brand new rotors quick. I will never use ceramic pads again!
Old 07-09-2012, 05:03 PM
327NUT's Avatar
I have an '02 F-250 Powerstroke, when it came time to do the front brakes a used "Performance Friction" ceramic pads.......outstanding!!! Put them on the rear when they were due. O'Rielly's wanted $58 for the front, found the same pads on ebay for $34....shipped. Well I see one of my brother Utah'ns had problems ??? mine never made a peep
Old 07-09-2012, 05:14 PM
302 Z28's Avatar
Installed Raybestos ceramic pads on the Tahoe. They work fantastic and do not make a sound. The key is buying quality ceramic pads and not parts house brands. Look for Raybestos, Wagner, or Bendix. Do some searching online and you will save some cash.
Vince
brake pad selection mitmaks Suspension - Brakes - Steering 1 08-14-2009 07:41 PM
abs brake pad change douger456 Suspension - Brakes - Steering 3 10-17-2008 04:23 PM
Nova brake pad question gilliganspl Suspension - Brakes - Steering 4 05-10-2007 05:56 PM
Rear Disc Brake Pad Replacement ccarccrazy Suspension - Brakes - Steering 3 01-13-2007 08:59 PM
Brake Pad Info Triaged Suspension - Brakes - Steering 0 03-28-2005 12:44 AM
