Disc brake rotor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 03:41 PM
New Member
Disc brake rotor
I have 11 inch Granada rotors on my Mustang 11 setup. What is the maximum run out accepted before turning is necessary. One rotor has .003 on pass side, drivers side is .007. I feel a slight pulsation when I first apply my non power brakes
Old 07-10-2005, 05:41 PM
aka Duke of URL
0.003"
The following errors occurred when this message was submitted:
The message you have entered is too short. Please lengthen your message to at least 10 characters.
Guess I will ask if you are using GM calipers on all that FORD metal...
Old 07-10-2005, 06:21 PM
Bumpstick's Avatar
Hammer and a torch
For the non-technical answer... We turn the brakes when we feel any pulsation because the norm is it will only get worse as its a wear/warp problem that 99% of the time wont fix itself...
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Disc brake rotor width? highway 1011 Suspension - Brakes - Steering 1 04-25-2003 04:54 PM
