Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brake swap for a 62 falcon
Old 04-15-2013, 07:31 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
I have a 62 Falcon sedan:
I bought manual disc brakes off front of a wrecked Maverick. I also removed the master cylinder and proportioning valve from the Maverick
New reproduction upper A arms for early Mustang fit the Falcon and had correct upper ball joint.
My lower ball on my Falcon fit the Maverick spindle.
I bought sleeve adapters for my 6 cyl tie rods to fit the Maverick spindles. Bolted parts on, a few new brake lines , rubber hoses, rebuild on calipers.
My Falcon stops well
The Following User Says Thank You to Crosley For This Useful Post:
h0trod (04-15-2013)
