disc brake swap for a 62 falcon - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 08:46 AM
if you beat my boat, well race
hello.
im slowly working on a 62 ford falcon ranchero.I would like to upgrade the front to disc.
what exactly is interchangable with this?
i would like to replace the control arms too, with new bushings.
without using an aftermarket mustang II kit.
appreciate it!
Old 04-15-2013, 09:05 AM
RWENUTS's Avatar
Look here for brakes.
Ford
Old 04-15-2013, 01:58 PM
Wiki Edits: 31
Welcome to CSRP sells reproduction Granada pieces that will work with some '63-up tie rod parts on your '62. Possibly the control arms need changed also. They sell everything.
Scarebirds kit requires machining. The drum itself is the hub, so you need to have the drum turned into a hub that a rotor can fit on. It works, but if you want to ditch 4 lug and go 5 lug, you need different parts, or the more expensive kit
Old 04-15-2013, 07:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have a 62 Falcon sedan:
I bought manual disc brakes off front of a wrecked Maverick. I also removed the master cylinder and proportioning valve from the Maverick
New reproduction upper A arms for early Mustang fit the Falcon and had correct upper ball joint.
My lower ball on my Falcon fit the Maverick spindle.
I bought sleeve adapters for my 6 cyl tie rods to fit the Maverick spindles. Bolted parts on, a few new brake lines , rubber hoses, rebuild on calipers.
My Falcon stops well
The Following User Says Thank You to Crosley For This Useful Post:
h0trod (04-15-2013)
62 Falcon disc brake conversion Jeff Van Stemp Suspension - Brakes - Steering 9 12-22-2012 08:14 AM
Disc Brake Conversion? 1962 Ford Falcon Futura? chadc Suspension - Brakes - Steering 8 01-23-2012 01:52 PM
1962 Falcon disc Brake conversion???? RUDY Suspension - Brakes - Steering 3 01-23-2012 08:33 AM
64 Falcon Brake Pedal Swap cjcyclone Suspension - Brakes - Steering 2 11-29-2010 08:53 PM
68 Firebird Disc Brake Swap blacktoothgrin Suspension - Brakes - Steering 12 02-16-2007 08:40 AM
