disc brake update - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2007, 07:36 PM
disc brake update
I'm working on a 69 chevy van.I would like to install disc brakes on the front to compliment the v-8 upgrade. Does anyone know of a set of rotors and wheel bearings that will fit the stock spindles on my straight axle? The suspension on these vans are not heavy duty and I'm hoping maybe to find a passenger car rotor that might work.Thanks in advance for any help or suggestions you may have. Dadsgarage
Old 07-30-2007, 02:09 AM
327NUT's Avatar
These guys have a lot of different setups, give Master Power a call at 1-888-249-9424 or see their website , www.mpbrakes.com/street. There in Mooresville NC....good luck, Dave
Old 07-30-2007, 08:34 AM
thanks
I really appreciate the info. I also found a suggestion in another thread about using late model slip on rotors on the original hubs. BRILLIANT!!! It is such a simple solution I can't believe my simple mind never thought of it!! That's why I like having other rodders to bounce problems and ideas around with. Thanks for your help.
Old 07-30-2007, 04:34 PM
If you haven't already checked Google VCVC they have the parts lists and brackets for the conversion I did it on my 64. It uses Nova rotors and the stock gm calipers.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
