disc brake way to sensitive..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2012, 09:50 PM
hello
I just convert my 71 nova to disc brake
everythings works fine.... may be way to much...
i have to be very carrefull with the pedal , and dont push all the way because
the brakes will lock the wheel
what can i do ?
thanks
Old 11-07-2012, 10:30 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Vincentnova View Post
hello
what can i do ?
thanks
Are you using the manual brake pedal and not the power brake pedal? Manual has a ratio of around 7:1, power has a ratio of around 4:1.
Old 11-07-2012, 10:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
hello
what can i do ?
thanks
Did you swap in a disc brake master cylinder? Or at least disable the residual pressure valving. Otherwise the residual pressure valve can hold pressure on the caliper, causing the brakes to drag and possibly overheat after driving for a while. This can also make the brakes touchy, but the main problem is brake drag and the drum master cylinder having the wrong bore size.
If that's OK you can increase the master cylinder bore diameter or decrease the caliper bore diameter, or decrease the pedal ratio.
I would try the pedal ratio first. See if you can move the clevis to a hole nearer the pedal than where it is now. This may also require an adjustment to the pushrod length.
Old 11-07-2012, 10:33 PM
please ignore my post
Old 11-08-2012, 12:09 AM
ok coool sounds good
i have a brake pedal from a 72 chevelle disc brake
Ill swap it
thanks a lot
brakes, pedal ratio
Help with 68 camaro emergency brake install disc brake jdp2603 Suspension - Brakes - Steering 4 02-13-2010 07:56 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
Street Rod brake pedal too sensitive !! HELP!! hemi43 Suspension - Brakes - Steering 3 11-07-2006 11:44 AM
Mecanical disc brake caliper for parking brake? bigun Suspension - Brakes - Steering 4 12-15-2005 08:43 PM
Why are some people so sensitive? CET Hotrodders' Lounge 14 02-23-2003 06:41 AM
