I still have the stock front end under my 54 f 100,I would like to upgrade to disc.,and add power steering,without stubbing it,if possible. I already have wheels with the stock bolt pattern and and would like to keep them on the truck.
Larry,
In my opinion you are expecting alot. I think I have seen where someone was rebuilding GM 605 PS boxes to fit in the F100s. I have not heard of an easy disk break conversion that does not involve a new front end. You might want to check out Stainless Steel brake Corp. I know they make disk brake conversions for alot of popular vehicles. I think an experienced machinest / fabricator could modify a set of existing rotors to fit on the hubs of the ford and then fab out the brackets to support a set of calipers. |
If you are willing to purchase a new kit, I would give Fat Man Fabrications a call first (704)545-0369. Let them know your plans, and see if they can help. Good Luck.
i have een tld th they are useing aspen,volare sub frame and suspension.but have not found someone that has done it.i have talked to my uncle and he is checking into how it is done.if i find out anyway how it is done i will get back
I have used Streetrod Manufacturing parts on 3 difernt projects and had very good luck i had a problem with 1 other project called skip andin a few minuts he figured out my problem and all is good i give this co 2 thums up and 5 stars
