-   -   disc brakes for 1961 Pontiac catalina (http://www.hotrodders.com/forum/disc-brakes-1961-pontiac-catalina-11642.html)
dan20 10-25-2001 02:03 PM
Does anybody know what disc brakes will fit on this car?
KULTULZ 10-28-2001 01:29 AM
It is usually cheaper to go the kit route rather than utilizing take-off parts from a later model-
-Stainless Steel Brakes-
-is one such supplier.
KULTULZ 11-07-2001 11:15 PM
Have you talked to -Master Power Brakes-?
They can make adaptors to fit calipers to your spindle. They also offer a kit for a 1961 Chev. Maybe they can adapt the kit to a Pontiac.
Phat 11-08-2001 03:13 AM
Just a thought look at corvette spindles from the early cars.I think they may just bolt on with disc and all. I seem to remember the spindle is the same style but i had to adapt the rear wheel bearing and after all the work noticed that the whole spindle with brakes worked . i did this a long time ago but check it out.Look to see if your balljoint points down with the spindle under the lower control arm(like the vette) I find the earlyer vette stuff pretty cheap(cause spindles dont get checked for matching # LOL )
