We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 01-19-2003, 01:39 PM
leo Renner leo Renner is offline
Post disc brakes 1968 galaxie conversion
I have a 68 ford galaxie 302 small block with power drum brakes. I need info on what type or year of car to get parts to convert to dis brakes. All info would be appreciated.
Old 01-20-2003, 03:41 PM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
KULTULZ's barnstar
Wiki editor
Last wiki edit: Finding vacuum leaks
Arrow
Well...
Any FORD/MERC of that era (1968/1970) would be the easiest to take the parts off of. A later FORD or 73/ TORINO will also work, but there may be a problem with ball joint/tie rod end wedge ends. But, they (spindles) can be machined to accept the earlier suspension parts or you may just be able to switch different year parts around to get the end result.
You have several possibilities. Just don't forget the master cylinder and proportioning valve upgrades also.
Old 01-20-2003, 04:49 PM
Post
Thanks KULTULZ for the info
Old 01-25-2003, 11:32 AM
murrsue's Avatar
murrsue murrsue is offline
Post
Check out www.texasinternet.com/~dsigns/james/Disc%20Brakes.htm for grear instructions. You can also search "Granada brakes" or "Granada conversion".
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
