disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2011, 03:11 PM
disc brakes
i would like to put disc brakes on front of my 46 ford sedan. does anyone know anybody that sells a good conversion kit.i would like to use my orginal spindels and straight axle. thanks
Old 07-05-2011, 04:00 PM
I have used Chassis Engineering kits before. Good quaility parts at reasonable prices. They have kits to use either the Chevrolet 5 on 4.75 wheel pattern or the Mopar 5 on 4.5 pattern. The Mopar and Ford BOTH are 5 on 4.5 so the Mopar rotars will fit Ford pattern wheels. The listing is for 1935 to 1940 Fords but the kit will work on a 1946 spindle.
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 12:41 AM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
disc brakes 39chevy Suspension - Brakes - Steering 5 09-25-2003 07:25 PM
