disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 11:25 PM
knuckles's Avatar
New Member
Last journal entry: 1962 chevy
disc brakes
i want to add a 97 camaro rear end to my 62 chevy i've got everything figured out but the brakes. i have disc brakes on the front ,do i need a proportoining valve to make the rear brakes work properly?
Old 03-20-2005, 07:48 AM
302 Z28's Avatar
Yes, you will need a proportioning valve and also a master cylinder designed for disc brake application.
Vince
Old 03-20-2005, 08:11 AM
poncho62's Avatar
Wiki Edits: 5
Use all the stuff from the Camaro donor.
Ontario Rodders
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
11.5" disc brakes big...enough? tundrafiend01 Suspension - Brakes - Steering 4 06-11-2004 08:03 AM
57 Chevy Disc Brakes.. CHEAP PLEASE 30chevycoupe Suspension - Brakes - Steering 4 05-04-2004 09:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
disc brakes black66 Suspension - Brakes - Steering 2 05-02-2003 06:15 PM
