Rear disc brakes
Depending on the system, you'll probably need the Roadmaster proportioning valve, too....Should just drop in, just like the rear axle....Get or borrow a pressure bleeder....And lots of brake fluid to flush out the entire system after the modifications....
Did that roadmaster happen to be a waggon? If it was it will have a 5 on 5 bolt pattern insted of the 5 on 4.75 bolt pattern that most of the sedans had....but all is not lost. The waggons came with "Cop" type (1C9?)suspensions on them which included 12" front brakes. Just take EVERYTHING and slap it onto your car and get some new wheels.
but i got the whole rear-end thanx again J |
You will probably need the master cylinder as well, drum/drum and most disc/drum masters are different from a disc/disc.
| Dent Repair | Randy Ferguson | Body - Exterior | 25 | 11-26-2005 09:00 PM |
| 63 sub disc brakes or no disc brakes | sub63 | Suspension - Brakes - Steering | 5 | 03-19-2005 11:31 PM |
| 57 Chevy Disc Brakes.. CHEAP PLEASE | 30chevycoupe | Suspension - Brakes - Steering | 4 | 05-04-2004 09:17 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| disc brakes | black66 | Suspension - Brakes - Steering | 2 | 05-02-2003 06:15 PM |
