Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brakes for a '64 Caddy
Old 12-06-2002, 03:22 PM
chrome_ashes chrome_ashes is offline
Post disc brakes for a '64 Caddy
I'm helping a friend with his '64 Cadillac Sedan de Ville and was wondering if anyone has ever swapped out the front drums for a disc setup. I know that the '67-'69 Cadillac suspension is the same and the swap should be fairly straight forward. The only problem is that the '69 rotors necessitate use of '69 wheels as the '64s won't fit.
Another concern is the modifications typically made for the booster to fit properly. the mounting stud holes are different from '64 to '69 and the brake lines from the master cylinder exit differently causing modifications to the inner fenders to be necessary for clearance. My friend does not want to modify any of the panels.
Does anyone have any ideas or suggestions?
