disc brakes for 67galaxy - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 02:49 PM
Will 1972full size ford front disc brake spindles interchange with my 1967 galaxy?
Old 01-15-2006, 03:21 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I just had a look on NAPA Prolink...
Ball Joints, Control Arm Bushings, etc seem to be the same for both years, although both years mention a possibility of a "press-in" or "bolt-in" Lower ball joints. The 1967 listing displayed p/n's for only 240 - 6 and 390 V/8 (although I know these cars alsocame wit a 289 V/8)
One could assume this to mean that the suspension systems were very similar, perhaps even identical as long as you're comparing apples to apples (press-in vs bolt-in).
I would extrapolate this to mean that spindles may be interchangable ... but that's just a guess. If you already have both vehicles (1 as a "donor"), I guess you do't have a lot to lose other than some effort and skinned knuckles.
May the "Fords" be with you!
Galaxie ...Star Wars ... get it? <corny>
Old 01-15-2006, 06:00 PM
reply
the 67 galaxy has a 390,the 72 has a352!Will this info help determin if they are bolt in or press in?
Old 01-15-2006, 06:18 PM
66GMC's Avatar
Sorry, but no ... I'm sure you'll have to look.
BTW ... unless some adverturesome individual (that's a politically correct term) PUT a 352 into that 1972 full-size car, it's likely a 351 (C?).
Old 01-15-2006, 08:20 PM
thanks
Others inform me that 352 is correct! Thanks anyway.
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Does the 76 Lincoln Continental come with 9" and disc Brakes Tri5Nerd Transmission - Rearend 8 08-23-2005 11:22 AM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
disc brakes black66 Suspension - Brakes - Steering 2 05-02-2003 06:15 PM
