Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2006, 04:36 PM
Disc Brakes
I've got a 10 bolt Drum Brake rear end out of a 71 camaro with 5 on 4-3/4 bolt pattern, and I want to bolt on disc brakes. (I'd like to avoid an aftermarket "bolt on kit because of the price and lack of immediate availability of wear parts)
can anyone answer one or all of the following questions.
1. will disc brakes off of a 12 bolt rear end also work?
2. would say disc brakes off of other 67-80 model year GM vehicles with 10 bolt rear ends work? if so which ones?
3. has anyone bought and used an aftermarket disc brake upgrade and do they use brake pads and rotors that can be purchased at local autoparts stores such as autozone, checker etc, or do the wear parts have to be catalog ordered.?
4. does anyone have a set of disc brakes which will fit my appliation for sale in the Denver, Colorado area?
thanks all
Old 05-05-2006, 10:12 PM
A few late 2nd-generation Firebirds came with rear discs from the factory, and since a Firebird is just a Camaro in fancy clothes, that setup would be good, but they're hard to find.
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
Does the 76 Lincoln Continental come with 9" and disc Brakes Tri5Nerd Transmission - Rearend 8 08-23-2005 12:22 PM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-20-2005 12:31 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
disc brakes black66 Suspension - Brakes - Steering 2 05-02-2003 07:15 PM
