Disc Brakes for 9"
I am new to this web site. And this queston probly been asked before.. I own a streetrod with a Ford 9" in it and I would like to install disc brakes on it. I would also like to use Ford parts.. I am told the disc from a 84 to 90 Mark Vll 8.8 rear brakes will fit a 9" I would like to hear from everyone, but also someone who has done it...
I am also running 14" wheels.. You may email me at rsafreed@verizon.net Thanks everyone. onestreetrodder. |
Hello. I used a set of calipers, mounting brackets and pads from a late 90's exlporer that bolted right on to my 9". I used a set of gm envoy rotors because i needed the chevy pattern for my s-10 but i could have just used the rotors from the explorer if i needed the 4.5 bolt pattern.
Vince |
Did you have the axle shafts redrilled? Either way, its interesting to know that the explorer brackets and all will work. Got any pics of the swap or the compelted install? Thanks, Brian |
I used a set of strange axles with the 5.3/4 bolt pattern. The ford bolt pattern is 5.5 i just forgot. I could take some pictures if you want. |
Ford 9" Disk Brakes
I put a 77 Lincoln 9" with rear disk in my 51 Dodge pickup (photos on here and on my website at www.oldtruck.sytes.net)
I was thinking about buying new parts for it anyways, and the old Lincoln parts are getting harder to find (besides expensive!). I found out that the place that did my IFS and installed the 4 bar and air bags in my truck, sell a bolt in ford 9" kit that uses standard GM rotors and metric calipers with E-Brake. (calipers about $40.00 and rotors about $35.00) I just have to get my axles re-drilled. It's a great solution for replacing rear drums or outdated disk brake parts with current disk brakes. Their webpage is www.jimweimerrodgarage.com and you can look at the brake kit HERE It's at the bottom of the page. Last edited by sonicweb; 01-16-2006 at 07:35 PM. |
Disc Brakes
S-10 What size of rims are you using..
Do you mean 4 3/4 instead of 5 3/4 on pattern size.. onestreetrodder. |
I have 15 " rims. I have the 5 on 4 & 3/4 small chevy bolt pattern.
I seen these on ebay
These are NEW Brackets to allow use of Big Lincoln VENTED rotors and Cadillac calipers with built in parking brakes on the rear of your Ford 8 inch or 9 Inch rear axle assembly. As long as your 60's or 70's Mustang, Torino, Montego, Cougar, Maverick, Granada, Comet, Ranchero, Fairlane, etc has NO rear differential gear cover, and the center section unbolts from the FRONT, then this is the bracket set that fits all except the uncommon Big-Bearing models. These are for use with the car 4-1/2 lug circle. ![]() http://steeltechsolutions.com/RDBINSTRWORKPAGE.html Explorer Swap http://mustangandfords.com/howto/28733/ Lincoln MK VII swap http://n.1asphost.com/SETeam/Ultrainfo.asp?Page_ID=11 http://www.mpbrakes.com/reardisc.htm let me know what way you go, i'm not sure what way i'm going yet. Mustangsaly |
| Dent Repair | Randy Ferguson | Body - Exterior | 25 | 11-26-2005 09:00 PM |
| Does the 76 Lincoln Continental come with 9" and disc Brakes | Tri5Nerd | Transmission - Rearend | 8 | 08-23-2005 11:22 AM |
| 63 sub disc brakes or no disc brakes | sub63 | Suspension - Brakes - Steering | 5 | 03-19-2005 11:31 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| disc brakes | black66 | Suspension - Brakes - Steering | 2 | 05-02-2003 06:15 PM |
