Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - disc brakes conversion
Old 08-14-2011, 09:38 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
A 69 should have a distrubution block. The drum brake and disc brake cars used the same block. There is a seperate hold off valve for the rear brakes on the brake line coming off the master cylinder. You can add a prop valve or use one of those adjustable valves for the rear brakes.
