-   -   disc brakes conversion (http://www.hotrodders.com/forum/disc-brakes-conversion-203691.html)
williambavila 08-14-2011 09:09 AM
Hey guys I am wanting to convert 1969 camaro brakes from drum to disc,does anyone know what years will work and what cars will interchange?
joe_padavano 08-14-2011 10:21 AM
1967-1972 A-body (Chevelle, Cutlass, etc)
1967-1969 F-body (Camaro/Firebird)
1968-1974 X-body (Nova, Ventura, etc)
The spindles on these cars are all the same, but you need to use your existing bolt-on steering arms. You can also convert your drum spindles to disk spindles with simple machining and save money:
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
williambavila 08-14-2011 08:41 PM
do you have any clue if a manual brake 1969 Camaro would have had a vale on it for brakes or not? I got this car in pieces and do not know if they sold this part too.lol I have a drum brake car and just need to know if it would have had a proportioning valve or not?
V8&4spd 08-14-2011 09:38 PM
A 69 should have a distrubution block. The drum brake and disc brake cars used the same block. There is a seperate hold off valve for the rear brakes on the brake line coming off the master cylinder. You can add a prop valve or use one of those adjustable valves for the rear brakes.
302 Z28 08-15-2011 09:03 AM
FWIW if you salvage parts from a donor car get the distribution block as well as the power booster. If they are bad be sure to get replacements per the donor car.
Vince
williambavila 08-21-2011 01:26 PM
I have been doing some reading and the dist,blocks are pretty much worthless after 40 psi. Can I just run a line from front port on mcyl and split to each of the front wheels? Then from rear port to rear wheels? Is this something that will work? :confused:
cdminter59 09-19-2012 10:44 PM
Just get a proportioning valve off a later model Camaro as long it is a disc/drum setup. You have to have the proportioning valve or else all the pressure would go to the front brakes.
Cape Cod Bob 09-20-2012 08:24 PM
Go to MP brakes and do some reading on the tech links
http://www.mpbrakes.com/:welcome:
