You have rust in the caliper, seizing it up.......get a new one.
Ontario Rodders |
The brake hose may be collapsed. Open the bleeder on that caliper if the brake frees up it is the hose. If it does not free up the caliper is probably rusty.
Artificial Intelligence is no match for Natural Stupidity Chet |
The make and year of the brakes would help. Besides the piston and bore being sticky, if they're floating calipers (which is likely the case) the bushings and/or retaining pins (and the rubber grommets) that allow the caliper to float could be bent, seized or worn. With the piston retracted, the caliper should be able to be moved in and out by hand.
The caliper mount can be bent or damaged, which could put the caliper in a bind. There are points that have to be cleaned of dirt, grease and rust before giving them an application of caliper grease. |
Another thing that can affect this particular truck's front brakes, is the front brake line retainer that is hooked to the A-arm. The rubber brake line goes through this metal retainer, and over time (especially in areas where salt is used on the roads during winter) the retainer will rust up its ID. This rust can actually pinch off the rubber line- I had this happen on a '76 Blazer that was originally from PA and had a fair amount of rust. In my case, the brakes became locked up while towing a trailer. They would "bleed down" given enough time, but still would drag badly after applying them, until I found the problem. The same thing can also happen from the retainer getting hit hard enough to bend it. I doubt hitting the caliper would've helped, though. |
if there are any issues at all change the caliper, rebuilts are cheap and you can get them loaded with new pads as well.
| Brakes Locked | bosco200 | Suspension - Brakes - Steering | 3 | 08-07-2009 12:28 PM |
| Need Help With My Brakes | S10 Racer | Suspension - Brakes - Steering | 4 | 01-18-2009 02:00 PM |
| Hotrodders Knowledge Base: Suspension - Brakes - Steering | Jon | Suspension - Brakes - Steering | 0 | 11-26-2005 06:29 PM |
| G body with manual brakes - it works! - pics | dh79 | Suspension - Brakes - Steering | 7 | 08-27-2005 10:55 PM |
| Brakes locking up in non ABS system | nprfan | Suspension - Brakes - Steering | 9 | 08-24-2005 12:37 PM |
