Disc Brakes Locking Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2013, 01:40 PM
Got a 37 Ford with 4 wheel discs and metric GM calipers. About 6 months ago, my front brakes started locking up. I replaced the MC because I figured that was the obvious answer because there was rust in the front brake reservoir. Surprisingly, that didn't fix it. I removed the residual valve, inspected it, and it looked fine. I finally just bought another one after having nothing else to blame it on. The brakes worked better than ever before, and life was great. I shut her down over the winter and spring. The other day, I got in it, and the brakes felt really firm. Almost too firm. After a few pumps of the pedal, I started to feel resistance on the car. It got a little worse at every stop. By just 5 miles, they were almost locked up. After about 15 minutes just sitting in a parking lot, they started to loosen up. I managed to get home without touching the brake.
I checked the pedal, and nothing was binding. The MC fluid looks clean. All four corners are locking and I just don't know what the deal is. I am using a Corvette style MC and 2# residual valves. Any suggestions?
Old 07-14-2013, 02:29 PM
sedanbob's Avatar
Are your brakes manual, or do you have a booster? If you have a booster, did you check the clearance on the pushrod - if there isn't sufficient clearance, the booster could be applying the brakes without you touching the pedal.
Old 07-14-2013, 07:34 PM
I have power brakes with a booster. I will check that out. Thanks.
Old 07-16-2013, 06:30 AM
I checked it out yesterday, and the booster pushrod is pushing in the MC about 1/8". The car was cold, and I hadn't touched the pedal, if that makes any difference.
What's proper way to have it set up. Does the pushrod need to be barely touching the MC? Does there need to be a little slack?
Old 07-16-2013, 11:22 AM
sedanbob's Avatar
There needs to be a small gap. The procedure for measuring is in this attachment, pages 52-53 - they recommend .1 to .5 mm (small, but necessary).
Here's the attachment: http://www.autoshop101.com/forms/brake05.pdf
Hope this helps.
Old 07-16-2013, 01:09 PM
1971BB427's Avatar
I had a similar problem with drum brakes on my present project. Couldn't get them to release, and couldn't even get them bled properly. Had all sorts of trouble, and eventually decided to pull the master.
While pulling the master I noticed pressure from the brake operating rod, so I tried to adjust some free play into the rod. Since I'd swapped from a single master to a dual, it seems the operating rod was too long. I ended up having to cut things and rework it to get free pedal play, but once I did it all worked perfect.
This is a drum-drum system, with no booster, so it doesn't have to be power brakes to have the same problem.
Old 07-16-2013, 01:23 PM
ajtorsiello's Avatar
Had the same problem on my 34 ford. I also had to shorten the rod on the booster. Seemed cold it was OK but after it got hot it would bind up.
Alan
Old 07-16-2013, 03:05 PM
Thanks bob. It's always exciting when you find a solution to frustrating problem.
When mine worked okay, it was in the late fall. I'm not sure if it's coincidence or that temp plays a part.
Old 07-16-2013, 05:40 PM
sedanbob's Avatar
I hope that fixes it for you. Let us know either way.
brakes locking up and stumped scottsdale kid Suspension - Brakes - Steering 12 06-16-2012 10:09 PM
rear brakes locking up tcoop Suspension - Brakes - Steering 11 05-22-2010 03:09 PM
front disc locking up loctite Suspension - Brakes - Steering 11 04-03-2009 06:58 AM
Brakes gradually locking up fastrehotrods Suspension - Brakes - Steering 13 12-16-2006 01:22 AM
Locking drum brakes burninrubbah617 Suspension - Brakes - Steering 1 01-15-2006 02:09 PM
