Disc brakes model a Ibeam front - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2007, 08:31 AM
31 five window
Last journal entry: grill and rear end
I bought an unfinished project,1931 model A 5 window coupe.It has a super bell 4" drop I beam axle and aftermarket 37 to 41 spindles w/no arms. I am looking in speedway and was wondering if there is any track width differance between the pre 78 disc conversion and the 78 up kit? Also is one better than the other and reason why? I want the chevy bolt pattern 5 on 4 3/4.Any help would be great.
Old 11-13-2007, 06:50 PM
Youngster's Avatar
Disc brakes model A I beam front
The difference between the two brake kits is that the pre-'78 uses standard hardware and the post-'78 uses metric. Other than that and the price there isn't any difference.
When you get around to buying your steering arms for your spindles, go to Chassis engineering. They market arms that the mounting bolts go through and are nutted. In the other type of arms, the bolt goes into a blind hole. The CE arms come in two drops. you are going to want the ones for a model A, the deeper drop, for your axle.
Youngster
Old 11-13-2007, 06:56 PM
31 five window
Thanks alot!!! That is what I thought but wanted to make sure, also thanks for the tip on arms.
Front Brakes for 48 Olds dburns Suspension - Brakes - Steering 12 10-09-2011 08:54 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
making front drum into front disc.....? barbiekiller Suspension - Brakes - Steering 3 05-01-2007 06:57 PM
32 chevy front axle needs disc brakes karlslot Suspension - Brakes - Steering 4 04-28-2007 07:06 PM
Front disc brakes 50 Cadillac stock spindles badazz55 Suspension - Brakes - Steering 2 11-23-2005 05:20 PM
