Hi,
Have you considered a Hydro-boost brake system? it's quite compact, but you'll need a ps pump. Good luck, rich |
It will work fine....A friend has a 68 Corvette........no PB....
Remember though, the MC on disk/disk is valved differently than disk/drum. Proportioning valve too.
Ontario Rodders |
Hi again,
Yes, discs require more pressure. Take care, rich |
2000 something S10 came with rear disc brakes, that proportioning valve may work.My son in laws 65 Chevy truck has 4 wheel discs with no power and it stops fine.My daughter drives it and she is only 4' 10" and has no problems.An adjustable proportioning valve is probably your best bet.
Thanks! |
Will work fine as long as you get the correct master cylinder. 427 435hp Corvettes were availibale from the factory with 4 wheel manual disc brakes.
I think the residual valve is only needed for a vehicle that has the master cylinder mounted at or below the level of the wheel cylinders, as in frame monted. The proper master cylinder is far more important than the residual valves. Also the pedal ratio needs to me checked and improved if necessary. Vince |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Power for brakes | Mel Smith | General Rodding Tech | 12 | 03-15-2007 10:23 AM |
| Dent Repair | Randy Ferguson | Body - Exterior | 25 | 11-26-2005 09:00 PM |
| Does the 76 Lincoln Continental come with 9" and disc Brakes | Tri5Nerd | Transmission - Rearend | 8 | 08-23-2005 11:22 AM |
| 63 sub disc brakes or no disc brakes | sub63 | Suspension - Brakes - Steering | 5 | 03-19-2005 11:31 PM |
