disc breakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 08:47 AM
disc breakes
i have a 1971 chevelle with drum brakes. i want to change with disc brakes what vehicle will work.....
Old 03-11-2010, 08:52 AM
delawarebill's Avatar
drum to disc
just wondering if u just went to jeggs or sumitt and ck'd the pricing to do what u want... your going to buy new calip and pads and drums anyways.. and this will give u the adapter plate you'll need too...
Old 03-11-2010, 08:57 AM
wretched ratchet's Avatar
one full turn after it squeeks
First of all, Welcome to the Forum, and secondly, if you will post this question in the "Steering-Brakes-Suspension" Thread, you will get more viewers than here on the Newbie Thread.
When I changed my '55 to power front disc brakes we used a conversion kit and the cost wasn't that bad either.
Old 03-11-2010, 10:30 AM
327NUT's Avatar
.....or you can go to www.speedwaymotors.com , they have complete conversions.
Old 03-11-2010, 10:38 AM
prostreet6t9's Avatar
Differential/Driveline
Pull off your spindle and have a machine shop mill off the anchor that the top of the shoe sits. Then do a search for a Disc brake caliper mount bracket. I've seen them on Ebay and others. Loaded Calipers and Hub/Rotor's can be bought at your local auto parts store.
Old 03-11-2010, 03:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, I went with SSBC stanless steel brake corperation on my 67 camaro conversion kit, works pretty well you would have to check the prices,JMO
Cole
Old 03-11-2010, 09:55 PM
The anchor pad has to be shortened by about 5/8" or so. www.nnnova.com used to sell machined spindles on an exchange basis, but I don't know if they still do.
'68-'74 Nova spindles and brake parts will swap, but don't use Nova steering arms on a Chevelle.
Old 03-12-2010, 03:19 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
You may want to drop that high flying front end a couple of inches also, so look at some dropped spindles (2") that usually come in the kit also. Look at Jegs and Summit on line. Or MP Brakes (Master Power Brakes) http://www.mpbrakes.com/
Old 03-14-2010, 04:41 AM
fast68's Avatar
likes chevy trucks & boobies
any gm mid sized car with the same steering tie rod locations will work
front steer or rear steer
whichever it has
we have a 72 and i forgot which it is and if its even disc or drum
its a gold with black stripes SS with BB and 4 speed,, so its probably disc,,,
its sitting out back rotting away into the ground again though....
its so far gone already that i dont even look at it anymore.
needs virtually all sheetmetal replaced except for like one door and maybe one fender possibly..
too bad...
i know someone with a '68 sbc 4 speed one he drives it all the time and theres a few more around these days, its crazy to see around each summer, just so uncommon...
hmm,..
good luck!
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
