Disc conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2013, 06:03 AM
Disc conversion
hi everyone :-) hopefully I can get some advice on an ongoing problem
I installed the front disc brake conversion.bencj bled the MC and then installed the kit with booster.i then bled rear and front brakes. I have a firm pedal until I start the car then pedal goes way down before brakes actuall engage shut off car and brakes firm again ? I put a new hose on intake to booster thinking might have a vacume leak but still same symtons. this is brand new kit from CPP and advice appreciated ohh I forgot to mentio that I did have the clevis pin in the top hole on pedal so I moved it down to other hole for power brakes . could it be I just need to adjust the rod that goes to the bboter thru the firewall ??
thanks fo any help guys
Old 09-23-2013, 07:36 AM
RWENUTS's Avatar
Of course you adjust the rod.
Mc for fr/rr disc conversion 10Tonhammer Suspension - Brakes - Steering 1 09-20-2012 01:37 PM
Power Booster for Disc/Disc Conversion in '64 Impal SeniorRodder Suspension - Brakes - Steering 1 08-05-2012 09:14 PM
Disc conversion Ray ray64 Suspension - Brakes - Steering 1 03-01-2012 02:08 PM
Disc/disc conversion... MC and lines leedhead3 Suspension - Brakes - Steering 5 03-05-2011 07:25 PM
Disc Brake Conversion 57tommy Suspension - Brakes - Steering 9 08-19-2003 03:40 PM
