-   -   Disc on disc? (http://www.hotrodders.com/forum/disc-disc-221153.html)
wibas 06-30-2012 06:33 AM
Disc on disc?
What master cylinder to use with 11" front GM disc and 11" rear Ford disc? I have arround 17" vac at idle. Do I use power or manual? I have not checked the pedal ratio yet. This is on a street rod and will be firewall mounted. Thanks.
cobalt327 06-30-2012 07:31 AM
Ideally you'd want a bit more vacuum than that, but if you're sure you do have that available at idle, you can use a power brake booster. You're going to want about a 1200 psi capability, so best bet is to use a 9 inch dual diaphragm booster. Some info is here.
wibas 07-01-2012 07:52 PM
Hey thatnks for the info. What about using a hydrobooster?
cobalt327 07-01-2012 08:41 PM
That is surely an option.;)
