Disc on disc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2012, 05:33 AM
Disc on disc?
What master cylinder to use with 11" front GM disc and 11" rear Ford disc? I have arround 17" vac at idle. Do I use power or manual? I have not checked the pedal ratio yet. This is on a street rod and will be firewall mounted. Thanks.
Old 06-30-2012, 06:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ideally you'd want a bit more vacuum than that, but if you're sure you do have that available at idle, you can use a power brake booster. You're going to want about a 1200 psi capability, so best bet is to use a 9 inch dual diaphragm booster. Some info is here.
Old 07-01-2012, 06:52 PM
Hey thatnks for the info. What about using a hydrobooster?
Old 07-01-2012, 07:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That is surely an option.
69 Impala Disc/Disc Kit Suggestions 69redeemed Suspension - Brakes - Steering 1 11-08-2011 08:32 PM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
GM disc/disc master cylinder kleen56 Suspension - Brakes - Steering 11 10-16-2008 11:11 PM
Disc/Disc vs Disc/Drum master cylinders rlvirago Suspension - Brakes - Steering 6 02-28-2007 03:33 AM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 05:08 PM
