Originally Posted by rlvirago
What is the difference between disc/disc and disc/drum master cylinders, if any and can a disc/drum cylinder be used on a disc/disc set up?
The disc/disc will have a larger fluid reservoir to initiate rear caliper piston movement. The disc/drum will have a smaller rear system reservoir and most likely will include a 10# residual pressure valve, not needed (or wanted) on four wheel disc.
Not interchangeable.
