Disc/drum brake set up... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-11-2011, 10:57 PM
Last journal entry: It's getting there
You only need a residual valve when your master cylinder is mounted below the wheel cylinders. The valve keeps the brake fluid from draining back to the M/C.
Drum/Disc Brake Proportioning Valve Help leejoy Suspension - Brakes - Steering 2 03-22-2010 10:59 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 10:38 AM
Disc/Disc vs Disc/Drum master cylinders rlvirago Suspension - Brakes - Steering 6 02-28-2007 04:33 AM
drum to drum or disc to disc width? swoodard23 Transmission - Rearend 3 12-30-2004 03:51 PM
Master cylinder: Disc/drum vs. drum/drum wp442 Suspension - Brakes - Steering 4 09-28-2004 03:46 PM
