disc/drum brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2009, 08:10 AM
disc/drum brakes
O.K, lets see if I can get this right. 2psi residual valve on the front discs,
10 in back. good. Do I need a adjustable proportioning valve? Non boosted
set-up.
Old 05-10-2009, 09:19 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can run a adjustable proportioning valve on Non boosted or boosted
set-up. I have one on my non power brakes it really helps to tune in the brakes i think. Cole
Old 05-10-2009, 09:37 AM
powerrodsmike's Avatar
Wiki Edits: 161
Yes, you should run an adjustable proportioning valve....Another good addition to any disc/drum system that does not have a true combination valve is a stand alone metering valve in the front brake line.
It's function is to let the rears engage first, this is especially helpful at low speeds and on slippery surfaces.
This valve can be used with an adjustable proportioning valve, and the residual pressure valves.
Most all cars with a combination valve have a metering valve incorporated into them.
http://auto.howstuffworks.com/auto-p...ter-brake2.htm
Speedway sells them , as do several other companies.
http://www.speedwaymotors.com/Brake-...alve,8904.html
Lots of folks run without them, but I don't care to build anyone a system without one anymore. They make the brakes feel much more controllable.
Check this thread out.
Splitting front brake lines.
Later, mikey
BE different....ACT normal.
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
Disc/Drum Brakes, no rear Cape Cod Bob Suspension - Brakes - Steering 15 06-06-2008 02:37 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
